15 amp aftermarket headlight switch okay to use?
Old Sep 8, 2012 | 07:17 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
So, I redid 100% of the wiring in my '88. The stock headlight switch basically had it's own 10gauge wire from the battery and then 14gauge (I think) wires heading to each of the things the headlight switch powered, each making pitstops along the way at the fusebox like this...
Code:
                       /---{fuse}---(headlights)
[[battery]]===[switch]---{fuse}---(park lights)
                       \---{fuse}---(dash lights)
I have 2 questions:
1. Mine now has the same setup except I have a 25 amp fuse on the 10gauge from the battery and no fuses after the headlight switch like this...
Code:
                              /---(headlights)
[[battery]]==={fuse}=[switch]---(park lights)
                              \---(dash lights)
Is this a problem at all? Will it be fine or MUST I have the fuses on each of the out-going lines?
2. All the aftermarket light switches I'm finding are all 15 amp. One area I'm grey on is determining proper fuse\amperage size. I assumed the switch would need 25 or 30 amps because it has it's own dedicated 10gauge from the battery.
Old Sep 8, 2012 | 07:36 PM
irocwagon's Avatar
Car: camaro84.87iroc,91vert
Engine: Lt1, 383tpi,350tbi
Transmission: t56,T5,T5
Axle/Gears: 4thgenunknown,373,323?
Re: 15 amp aftermarket headlight switch okay to use?
Are you using a relay
Old Sep 8, 2012 | 07:53 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
Not for the headlights, no.
Old Sep 9, 2012 | 07:46 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
When ever we replace the headlight switch on thirdgen's people have been installing relays so the headlight voltage doesn't have to go through the switch.
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Jk_Under
Sep 2, 2015 10:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
