Tpi to Carb
Old Sep 11, 2012 | 11:15 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Tpi to Carb
I know people hate this but got no choice want to drive my car and cant figure out my problems.... can anyone help me and let me know what i need to make my 91 z28 carb...as far as wiring my distributer can i use my 91 and what other issues might i run into other than buyin a carb and intake thanks for any advice...!!!!
Old Sep 11, 2012 | 11:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Tpi to Carb
you need to use a vacuum advance distributor not a computer controlled distributor.
Old Sep 11, 2012 | 11:36 PM
carrelljustin's Avatar
Car: 1989 Camaro RS
Engine: Soon to be LS.
Axle/Gears: Need some
Re: Tpi to Carb
Like tuned said, you are going to need to get a new distributor. The one that is on the car is set up to work with the factory computer. I just recently had to go threw a rats nest of wires in my 89 because the guy I got the car from did a hack job on it when he tried to convert to carb. I removed all the wiring for the pcm and re wired the whole car. So if you need any help feel free to hit me up.
Old Sep 13, 2012 | 05:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tpi to Carb
https://www.thirdgen.org/carbswap
http://5finger.8m.com/tpi2carb/tpi2carb.html
https://www.thirdgen.org/torqueswitch
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
