Right side blinker doesnt blink?????WEIRD???
Old Sep 12, 2012 | 02:10 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my 84 Z28 when I go to make a right turn I put my right turn signal but the bulbs light up but they don't ever flash they just stay on, but when I turn the left side surprisingly they do blink...whats could be causing this??
and this has probably already been asked but how do I adjust the blinker rate?I want to make mine blink at a faster rate if possible, thanks!
Old Sep 12, 2012 | 04:51 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: Right side blinker doesnt blink?????WEIRD???
One of your right side bulbs might be burned out. They're dual filament, so you'll have to physically inspect.
Old Sep 12, 2012 | 07:41 AM
fervernt's Avatar
Car: 91 firebird Formula 350
Transmission: N/A, working on a t5 swap
Axle/Gears: 3.73 posi
Check the bulbs like posted above, and if they're good its your flasher. I had the same problem last year and it was the flasher for me. Its an easy 5 min job to replace it.
Old Sep 12, 2012 | 09:40 AM
calgutie's Avatar
Car: 1984 Z28
kinda of a dum question but how do i check the flasher>?
Old Sep 12, 2012 | 10:46 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Think, Therefore I Blink
The fastest way is to swap it with a new one.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
Old Sep 12, 2012 | 10:52 AM
calgutie's Avatar
Car: 1984 Z28
ye but where is it located?
Old Sep 12, 2012 | 12:11 PM
NINÅ's Avatar
Transmission: 765R4
The turn signal flasher is clipped onto the fuse panel, as delivered from the factory.
However if it has been replaced it might just be hanging in the maze of wires.
It’s round and approximately 1¼” diameter.
The Fuse Panel is located behind a door which is up and to the left of the brake pedal.
Happy Racing!
Old Sep 12, 2012 | 01:26 PM
fervernt's Avatar
Re: I Think, Therefore I Blink
Happy Racing!
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
Jk_Under
Sep 2, 2015 10:59 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
novaderrik
Aug 10, 2015 12:44 PM
