Name the wires, win a prize!!!
Old Sep 16, 2012 | 04:21 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
I have most of the drivers side harness hooked up to the 350 after swapping from 305 cfi to 350 carb but there are a few loose ends that i am not sure what they go to. the red single wire is on the drivers side on the firewall behind the wheel well. the other single wire is on the passenger side and comes out of the harness. thanks for any help.
Shawn
Last edited by dangerboy; Sep 16, 2012 at 04:53 PM. Reason: part of the question was answered
Old Sep 16, 2012 | 04:27 PM
87cam305's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 305 (LG4)
Re: Name the wires, win a prize!!!
first one not sure
second one no picture is showing
third one is to your a/c compressor clutch
Old Sep 16, 2012 | 04:53 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
thank you for helping me cross that one off the list.
Shawn
Old Sep 16, 2012 | 10:33 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Red one by the C100 is the fuel pump test connector to the relay.
2nd one I think may have been the timing disconnect for adjusting base timing.
Could also be an O2 sensor plug, need a shot from further away to know where its actually located.
Old Sep 17, 2012 | 07:46 PM
dangerboy's Avatar
Car: 83 Trans Am
Engine: 350 Carb'd
I dont think it went to the o2 sensor but i will double check it tomorrow against the o2 sensor. Everything i read on this swap said that the ecm harness (passenger side) was no longer needed but from what you said and my own examining the sensor it seems like the fuel pump and oil pressure gauge were in that harness. Am i better off hooking the ecm and harness back up to have the fuel pump relay and oil pressure sending unit connection or is there a more common fix to this? I cant seem to find too much info specific to swapping a crossfire motor, mostly just unanswered questions or answers beyond my ability to understand. Thanks for the help.
Shawn
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Linson
Aug 21, 2015 02:12 PM
