Can I wire a aftermarket mechanical temp gauge on stock manifold?
Old Oct 6, 2012 | 11:35 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 84 z28 with a LG4 Carbed engine and I wanted to know if it was possible to wire an aftermarket mechanical temp gauge and mount the probe somewhere on the manifold? Is there something I could replace it and insert the probe into??
Also what is the sensor that's on my thermostat housing, could I remove that and stick my probe into it? and if not what exactly does that sensor do and how do I know if its working because I don't think it functions on my car...
Old Oct 6, 2012 | 03:22 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Can I wire a aftermarket mechanical temp gauge on stock manifold?
I don't know if you'll be able to find a place to put it in the intake, but you can certainly stick it in one of the heads. Each one has two plugged holes on the side that go into the water jacket.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
R3500
Aug 17, 2015 12:16 PM
