Headlight cover problem
Old Oct 10, 2012 | 12:20 PM
greekknight's Avatar
I have a 1982 Pontiac Trans am and my passenger's side headlight cover has a problem. When I open the lights both covers open with no problems but when I close them, the one that is at the passenger's side always stays open and I have to close it manually. Do you know what the problem can be?
Old Oct 11, 2012 | 01:34 AM
Re: Headlight cover problem
Anyone?
Old Oct 20, 2012 | 11:18 PM
rob 86 firebird's Avatar
The problem is the relay. There are individual relays for each headlight as well as a master relay for both.
Old Oct 21, 2012 | 12:52 PM
Thank you for your reply,
Something I forgot to mention is that some times this head light cover will close without a problem, for examble if I try to close the lights ten times, one time will work as normal...
Old Oct 21, 2012 | 04:20 PM
try checking the connections to each relay
Old Oct 22, 2012 | 11:22 AM
Thank you very much for your help!
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
