Shorted wiring harness?
Old Oct 15, 2012 | 10:28 PM
destinyawaits's Avatar
Hello Everyone,
So I have been working on my 85 trans am for about 3 years haha, and finally got it on the road and inspected. So after the first week of driving it, the car lost power on the highway...
So I was moving the harness around to see what was going on and it was touching the header near the alternator. While i was moving it around it sparked and caught fire but I was able to blow it out .
So now my car is not working again and I don't know what to do with the wires (how to figure out which ones are work and which are not).
- I know that the headlights still work but not the ignition or the windows.
Thanks Andrew
Old Oct 15, 2012 | 11:50 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Shorted wiring harness?
probably blew a fusible link when the short occured-fusible links connect to the positive stud on the starter motor.
Old Oct 16, 2012 | 03:21 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Zip Ties. I also use gasket maker and glue them where I want them. They make asbestos looking plug wire cover that works fairly well.
Old Oct 17, 2012 | 08:48 PM
Alright so today I worked on pulling the wire up for the fuse able link. And this what I found, the wire total blow apart. The first two pictures are the wire. The last is a fuse able link pep boys suggested.
So now my question is..... should I use this fuse able link and connect the wire or just buy some plain wire and connect them?
Thanks Andrew
Attached Thumbnails Shorted wiring harness?-img-20121017-00006.jpg   Shorted wiring harness?-img-20121017-00004.jpg   Shorted wiring harness?-img-20121017-00007.jpg
Old Oct 17, 2012 | 11:52 PM
morgsie's Avatar
replaceable fuse will not cut it. you need to get a FUSEABLE link. try google if you are confused on what this is.
Old Oct 24, 2012 | 10:52 PM
Great I found the wire at NAPA and installed it over the weekend.
Car started right up, took the T-Tops off and went for a Sunday cruise, awesome!
now I have to figure out about the throttle, sometimes it as a really good push and moves but most of the time it just feels slow.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 21, 2015 01:54 AM
