86 firebird head light help
Old Oct 16, 2012 | 10:22 PM
jdtm84's Avatar
Car: 86 firebird
Engine: 5.7
Transmission: currently T350
Axle/Gears: stock for 2.8 V6
Motors work and crank down automatically but only crank open by hand. The relays click both ways and when the headlights are off they will not let me crank them up, they just keep going back down, when on I can crank them up. Is there a controller on this car to make them go up and down or is it all in the headlight switch. If there is a controller where is it, pics would be good.
Old Oct 20, 2012 | 11:13 PM
rob 86 firebird's Avatar
Re: 86 firebird head light help
On the 86 Firebird there are 3 relays that operate the headlights. one is a master relay for both headlights. If they are both doing it that is the problem relay. The other 2 relays are for each headlight. If one light is working properly it is one of those relays. It may seem the relay is working if they go up however the relay reverses polarity to go down as well. All 3 relays are the same part number so they can be swapped around to find out which one is bad. A Haynes manual will be your best friend in fixing this.
justin57
Aug 20, 2015 07:05 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
