1986 transam headlight motor help
Car: 1986 trans am
Engine: 355 sbc
Transmission: th 350
wires burnt up trying to run new wires to relay im getting no were can anyone tell me which wires go were on the relay please help thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 1986 transam headlight motor help
on the 92 there is a control box for the lights on the firewall on top of the brake booster, its about 4" square maybe with mulit wire plugs on each end. There are also 2 fuses under the dash between the console and the steering column in case you didnt know and may just have a blow fuse.
Car: 1986 trans am
Engine: 355 sbc
update went to the salvage yard and picked up wiring harness for headlights from firewall plug all the way to headlights now there going up but not closing started swaping relays got driverside to go up and down but nothing at all on passengerside returned relays from were they were orignaly from salvage yard harness and again go up but not down is it a relay ? please help
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
