86 TA headlights won't flip up
Old Oct 28, 2012 | 12:54 PM
Ts1986TransAm's Avatar
Car: 1986 Trans Am
My lights won't flip up on my 86 TA. There is an isolation relay and 2 actuator relays. The pink wire is supposed to show 12V and it shows zero at the isolation relay and zero at both actuator relays.
I think the problem is the isolation relay (the one between the air cleaner & the passenger headlight) so I plan to start with that.
Does anyone have one they can sell me? I can't find one online. It shows part 10038949.
Old Nov 6, 2012 | 02:46 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: 86 TA headlights won't flip up
Id suggest if you have the electrical background..re wire the system with new bosch type relays.I fought with mine for some time..got the lights to flip up..but they passenger side wouldnt go down..and the foglights would stay on.I ditched the entire setups and changed to a 87+ headlight module and headlight motors.... made things simple and parts are more common.
Elephantismo
Feb 13, 2019 12:51 AM
Chevykid810
Sep 28, 2015 12:57 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
