*Pics*Rewiring harness questions about ses light and wire
Old Nov 4, 2012 | 03:47 PM
PurpleG20305TPI's Avatar
Car: 88 Chevy G20 Wagon Wheel Conv Van
Engine: 91 camaro z28 305 tpi 77k miles
Transmission: TH400
Hi, so im rewiring this cut harness. it was cut because the harness from the motor 91 305tpi the main fuse block didnt match. so, i have a wire that is Brown/white that is supposed to go to gauge cluster or used for cel.
This wire has 12v in the on position and when its grounded, the service engine light comes on.
Now my question is, if i wire this brn/wht wire with 12v to the ecm brn/white wire thats for the ses, will the 12v directly to the ecm harm it? or does it normally have 12v at the ses connector at the ecm?
Im afraid to connect it and kill my ecm. but those are the only brn/white wires, and i know that it is for the ses because when its grounded the light turns on.
Thanks for any help
Old Nov 4, 2012 | 05:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Rewiring harness questions about ses light and wire
Nearly every item controlled by the ECM has 12V going to it and then it is controlled
by going to ground at the ECM end
Old Nov 4, 2012 | 06:52 PM
Transmission: TH400
thanks for the info. ill hook up the light tomorrow and then try to retrieve the codes.
Old Nov 5, 2012 | 11:15 AM
Transmission: TH400
ok. so i wired the brn/white wire that is for the ses light to the brown wht wire i found coming from a plug near the ecm. if i follow the wire from the ecm, it goes to an extra plug that i dont have wired to anything because i dont know what its for. i have the ecm pinout for the 91 camaro tpi. but i dont see this 4th connector. heres what it looks like. it has a lot of pink/black wires and it looks important, but it doesnt make sense for the swap i have. i might have wired it wrong if this connector is one of the main outputs for my inject signals and what not. any idea?
Old Nov 5, 2012 | 06:54 PM
Transmission: TH400
Re: *Pics*Rewiring harness questions about ses light and wire
this clear plug has all the wires to operate the injectors and other sensors. had to wire it in. still working on it.
Old Nov 7, 2012 | 03:45 PM
Transmission: TH400
Bought all new shrink wrap and more solder today. gonna start fresh with what i know about that clear plug and permanently wire these until its perfecto. I WILL FIGURE THIS OUT!!
Old Nov 13, 2012 | 08:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That connector is the C207... May or may not have a diagram in the service manual (GM manual, doubt it's in Chilton's and I know it's not in Haynes). While you're at it, make sure all of the other wires are in the right holes or things like the fuel injectors aren't going to work (VATS fuel enable and injector power wires run through that connector as well as emissions and other power wires).
:edit: And get rid of that quick splice before it actually CUTS the wire it's attached to.
Old Nov 13, 2012 | 09:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Nov 14, 2012 | 09:28 AM
Transmission: TH400
Thanks guys. Ive got diagrams out the WaHoo right now. Also, ive come to have a pretty good understanding of the function and place of all the wires. ive completely rewired that clear plug(C207) and soldered, shrink wrapped, and conduit them. starting to look professional. i would like to haVE it completely rewired and running by the end of this week.
Thanks!!
Dean
Old Nov 14, 2012 | 10:20 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Thanks!!
Dean
It's so nice to see somebody fixing a harness for a change.
Old Nov 14, 2012 | 02:18 PM
Transmission: TH400
Ill get some pics of the finished job. i love cleaning up an engine bay. So i can tolerate wiring. Been enjoying this one though because now that it all makes sense, theres not much to do. and its so satisfying to see the end product.
ps. VSS retrofit came in and installed in 1 minute. very NIIICE!
Old Nov 15, 2012 | 09:29 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I'm looking forward to seeing those pics. Solder is definitely a good "upgrade" to the wiring; unlike crimping, it can last for 100 years.
Old Nov 15, 2012 | 12:12 PM
Transmission: TH400
Yeah, i gotta use the crimps and jumper block things while i figure the mess out. once i understand, then thats when the beauty begins.
peace
Dean
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
