flashers and hazzards wont blink!
Old Nov 13, 2012 | 03:40 PM
86zBowtie's Avatar
Car: 1988 sport coupe z
Engine: 350 :)
Transmission: 700r4 B&M tranny
Axle/Gears: 2.73?
my 88 sport coupe is really on my nerves, both hazzards and flashers just illuminate, no blinking. whats the most common thing i should look at? i plan to replace the flasher but what else should i do? thanks!
Old Nov 13, 2012 | 06:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: flashers and hazzards wont blink!
start by checking "ALL" bulbs & sockets . clean all sockets (scotch brite pads) brush inside of all sockets with a "LIGHT" coat of di-electric grease . clean base of all old bulbs (scotch brite again with a light coat of grease) . repair/replace any bad wires/connectors you might find . clean "ALL" dirty connectors you come across . all of the above apply to "ALL" elect. plugs , male & female . good luck .
Old Nov 13, 2012 | 07:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I don't disagree with tom for bulb checking but, the hazard flasher relay should work even if only one bulb work. Rare both fail together. Make sure you even have flasher relays to start
Hazard and turn are separate circuits using different flasher relays.
Old Nov 13, 2012 | 08:03 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Jut for clarification, there are no relays in the turn signal circuit, only flashers.
Old Nov 13, 2012 | 08:25 PM
deadbird's Avatar
Engine: TPI 305/ v6
Thank you for the correction Lou. Brainfart on my part, my mistake.
Old Nov 13, 2012 | 08:44 PM
BigBadLou's Avatar
Engine: TPI
No worries, I've had some of those myself.
Now for the million dollar question: what do brain farts smell like?
Old Nov 13, 2012 | 10:47 PM
deadbird's Avatar
Engine: TPI 305/ v6
In my case... probably similar to the same place my head resides a lot of the time...
Fronzizzle
Feb 9, 2017 09:31 AM
Jk_Under
Sep 2, 2015 10:59 PM
FastAndFurious
Dec 9, 2001 06:58 PM
Yellow Camaro
Jun 28, 2001 09:29 AM
