"Pulsing" Headlights and Interior lights
Old Nov 18, 2012 | 10:37 AM
resdwells's Avatar
Car: 1989 IROC-Z28
Transmission: 5-Speed
Axle/Gears: G92 with 3.45 Posi
Just bought my 89 IROC a few weeks ago. Have most of the mechanical issues resolved and now am switching gears to electronic ones. With the headlights on they (along with the interior dash lights) pulse at a fairly steady rate. My first guess was a bad alternator (which tested good). I've heard of people replacing the alternator any ways and having success.
Anyone out there with the same problem or an idea of where to start?
Old Nov 18, 2012 | 08:05 PM
Mike Massey's Avatar
Re: "Pulsing" Headlights and Interior lights
I also had a similar prob does it only do this at idle? and does it have an underdrive pulley? i wld also check all engine or chassis grounds and may even add some jus 2 cts
Old Nov 19, 2012 | 11:30 AM
resdwells's Avatar
Car: 1989 IROC-Z28
Hey Mike,
It does it at idle and highway RPM's (2500).
I'll have to check the pulley... Is there a page with what diameter it should be?
Old Nov 19, 2012 | 05:28 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Tell us more about the pulsing. What frequency/period does it pulse at? Does the frequency change with engine RPM? With vehicle speed? Does it pulse only with the engine running?
Does the pulsing frequency change with more load on the electrical system? (fans, A/C)
Can you tell whether the pulsing is discrete (sudden "jump" in brightness) or ramped (slow change, as if you turned a dimmer switch)?
Old Dec 13, 2012 | 10:34 AM
resdwells's Avatar
Car: 1989 IROC-Z28
Well here is a good one for you guys. I apparently fixed my issue.... My driver's side low/high beam lamp burned out. Replaced both it and the passenger's side and the pulse has gone away. With that being said I did notice that the driver's side lamp was a bit dimmer than the passenger's side when I bought the car a few months ago. So I am going to assume a bad ground or some type of internal "short" within the lamp???
Old Dec 13, 2012 | 12:15 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I had a lose ground wire on the passenger fender-inner fender area that was lose and caused me all sorts of problems. It wasn't that lose either but you could spin it with your hand with a little force.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Omega
Aug 10, 2015 12:46 PM
