What is this plug? i thinks its for canister purge or something *pic*
Old Nov 18, 2012 | 04:41 PM
PurpleG20305TPI's Avatar
Car: 88 Chevy G20 Wagon Wheel Conv Van
Engine: 91 camaro z28 305 tpi 77k miles
Transmission: TH400
In some schematics, i found that the green/ylw is for canister purge valve. but im in the middle of a swap to my van, so idk if i even have this canister and might need to splice it in somewhere else? any advice is much appreciated.
Old Nov 18, 2012 | 06:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: What is this plug? i thinks its for canister purge or something *pic*
Yes, that would be for the canister purge solenoid. Yours may have a round pin-type plug instead of the connector you have there.
Old Nov 18, 2012 | 09:13 PM
Transmission: TH400
Ok, ill check to see where mine is and rewire to this one. thanks a bunch. :-)
Old Nov 18, 2012 | 09:34 PM
Transmission: TH400
is this the canister purge solenoid? kinda under the distributor.
Old Nov 18, 2012 | 09:42 PM
Engine: 2.7L V6
Axle/Gears: 4.41
What color is the other wire? That MAY be an EGR solenoid.
Old Nov 18, 2012 | 10:05 PM
Transmission: TH400
not sure. this is the one that is supposed to have a piece of foam/filter where the hole is near the metal clips.
Old Nov 18, 2012 | 10:48 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
ERG solenoid.
Old Nov 19, 2012 | 12:57 PM
Transmission: TH400
Ok, where can i find the canister purge solenoid?
Old Nov 19, 2012 | 01:09 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
do you still have the emission diagram on the g20 ? the evap purge would have been on top of the ccp or on the manifold map bracket.
Old Nov 19, 2012 | 01:58 PM
Transmission: TH400
Yes i do but i dont see anything about an evap purge. also, whats a ccp? i got some pics of the old motor and carb and intake.
Old Nov 19, 2012 | 02:23 PM
Engine: Lb9
Transmission: M20
ccp = charcoal canister purge. You van may not use a ccp because of the gvw not positive but it would hook to the tbi port A.
Old Nov 19, 2012 | 02:26 PM
Transmission: TH400
i have a charcoal canister and a bunch of hoses but no wires aROUND.
What is port a on the tbi? what do you mean?
thanks
Old Nov 19, 2012 | 02:32 PM
Engine: Lb9
Transmission: M20
Typical tbi emissions
Old Nov 19, 2012 | 02:47 PM
Engine: Lb9
Transmission: M20
just looked at the schematic of the 747 ecm and do not see control of the solenoid. This must be controlled bye using a ported vacuum port or tvs.
Old Nov 19, 2012 | 05:31 PM
Transmission: TH400
so i wired everything except a couple wires that idk what are for. ppl/white from the fuse block, 2 dark brown wires, an extra pink with about 2v's, extra orange with 3v's.
i go to start it and it cranks and almost fired. i checked the ses and jumped the terminals and no code was present. just kept flashing code 12. but my batter began to die so i couldnt keep trying.
Old Nov 28, 2012 | 04:37 PM
Transmission: TH400
so what should i do with this plug? jump it/connect it to complete a circuit?
doesnt the ecm need a signal from a canister purge for emissions?
Old Nov 28, 2012 | 04:53 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If you have the old style canister, you can leave it unplugged and use a ported vacuum source to operate the purge valve.
DO NOT DIRECTLY JUMP THE WIRE OR YOU WILL FRY THE DRIVER IN THE ECM!
Old Nov 28, 2012 | 05:03 PM
Transmission: TH400
ok i wont jump it. so my stock emission purge/pcv hosing should plug into the purge valve and i can disregard the plug?
thanks
Old Nov 28, 2012 | 05:10 PM
Engine: Lb9
Transmission: M20
vaclinesformyiroc.jpg?t=1325217059
The port on the tb that gets used on tpi is manifold vacuum
Port A is the only ported vacuum you have you can delete these wires or wrap them up to prevent shorting and ecm damage.
Old Nov 28, 2012 | 08:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And then run the large line from its source straight to the canister while omitting the purge solenoid on the top of it (bottom port of the valve, under the ported vac hose, IIRC).
Old Nov 30, 2012 | 09:42 AM
Transmission: TH400
ok, thanks. but i have a 91 tpi speed density. it still applies though?
Old Nov 30, 2012 | 11:48 PM
Engine: Lb9
Transmission: M20
I think all you need to do is run the old hose that went to the tbi port A to the tpi throttlebody port A. I dont recall tbi trucks or vans having any other hose going to the engine. You might want to leave the pigtail intact incase Im incorrect and disconnect F7 at the ecm.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Jan 29, 2017 07:00 PM
project89
Sep 24, 2015 06:38 AM
