Distributor and Coil Wiring
Old Nov 24, 2012 | 12:19 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
I am upgrading from the older larger coil in cap style distributor to the newer smaller, remote coil distributor. I have purchased the gray and black (aftermarket) connectors for the coil, the 4 prong ignition module connector along with the 2 prong ignition module connector. I replaced everything inside the distributor, new accell module and external coil. I used nothing old other then the housing of the distributor. I now need to verify that I am going wire these connections correctly.
I have looked at several other threads and I am not understanding the wiring as explained. This is what i have determined from the various other threads. Is this right?
Thanks in advance for the help!
4 Wire Connection:
ECM Color 4 Pin Module Connector
D9 Black w/Red A
C7 Tan w/Black B
D8 Purple w/White C
C8 White D
2 Wire Connection Module Black Coil Connector Wire
A + Pink
B C White
Gray Coil Connector
Pink - Ignition wire
White - Tach wire
Last edited by tbroadfoot125; Nov 24, 2012 at 12:22 PM. Reason: Text pushed together and hard to read
Old Nov 24, 2012 | 01:25 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Distributor and Coil Wiring
Those pin-outs are correct.
Old Nov 24, 2012 | 01:29 PM
Engine: 87 5.0L TPI
Thank you for your reply. I'm going to start wiring the distributor in tomorrow. I still have to pick up some thermal paste later today for under the module.
Thanks again
Derick15
Sep 17, 2016 05:28 PM
stalkier
Dec 6, 2015 11:25 PM
midias
Aug 15, 2015 05:07 PM
cstrobel65
Aug 15, 2015 10:19 AM
L98GTA87
Aug 5, 2015 11:02 PM
