Where is the ground for parking light?
Old Nov 24, 2012 | 06:07 PM
iosigma's Avatar
Car: 2017 Jeep Cherokee
Transmission: 6 Speed, 5 Speed T-5
Okay, my left front parking lamp will not light up at all. I have a feeling that it's not grounding. Can someone tell me where the ground happens? I mean is it to the chassis nearby?
Old Nov 24, 2012 | 06:39 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Where is the ground for parking light?
If memory serves, each side of the headlight harness (park lights included) has its own ground up on the core support, just behind the headlights themselves. For just the park light, I'd look into the socket being the cause if the light itself is good, I've had more than one go bad. Maybe just a good cleaning will do the trick.
Old Nov 24, 2012 | 06:54 PM
iosigma's Avatar
what should i clean it with?
Old Nov 24, 2012 | 07:05 PM
Al Hasse's Avatar
Brake parts cleaner works well, doesn't leave a residue. A small amount of dielectric grease should go in the socket after you clean the old stuff out. Parts store should have both.
Old Nov 24, 2012 | 09:54 PM
iosigma's Avatar
Didn't have any brake parts cleaner so I used acetone, it works! Thanks!
LittleFranks
Sep 17, 2015 12:22 PM
Jk_Under
Sep 2, 2015 10:59 PM
DiabolicalRS
Aug 26, 2015 07:35 AM
tnrednneck
Aug 13, 2015 08:57 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
