help please
Old Dec 11, 2012 | 07:00 PM
Nasty rs's Avatar
Car: 91 rs
Engine: 355
Transmission: t5
Axle/Gears: 373's
help please
ok i know there is topics on this and believe me i have been searching but cant find the exact answer. car was origanaly a 305 tbi t5. swapped to carb and removed alot. the only thing i cant get to work is the fuel gauge. does it need the computer?(removed it). if not can i hard wire it from the sending unit straight to the cluster? the guage worked before swap but i did mess with wires when dissconecting in tank pump and setting up my new holley pump out side the tank. any info would be awsome thanks guys, its really irritating running out of gas!! please help
Old Dec 12, 2012 | 08:40 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Gage Rage
The gage does not need the “computer”.
Apparently a wire became disconnected during the swap.
Use an ohmmeter to see if the
purple wire from the tank connector is still connected to the dash connector located at the back of the IP.
Then make sure you didn’t disconnect the ground at the tank connector.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
Old Dec 12, 2012 | 04:47 PM
jay6891's Avatar
Car: 1985 Camaro
Engine: 430 hp 350
Axle/Gears: 342 posi
Re: Gage Rage
You did plug the harness back in when you reinstalled tank didnt you. The one right above he rear end. Did the same swap. No computer needed.
