Sender Help
Old Dec 29, 2012 | 04:07 PM
CAMAROBEAV's Avatar
Sender Help
Can anyone tell me what these senders are please?
The double one is at the back of the block
The single one is on the dipstick side of the engine
I guess its connected to the fault with my oil guage which does not work at all
Just need to know what to but and where to put it !
Hop you guys can help?
Old Dec 29, 2012 | 07:34 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Sender Help
The first picture shows two oil pressure sensors.
On our Chevy's the sensor uses a single wire, these might be aftermarket units.
The second one is your knock sensor. Connects to a single wire as well.
Old Dec 30, 2012 | 12:58 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Sender Help
the oil pressure sensors shown are just on/off pressure switches-no wonder the oil pressure gauge doesn't work.The single terminal one probably meant for warning light,the dual terminal one likely for fuel pump turn-on-(in factory setup,actually the "failsafe"to complete circuit to fuel pump if the fuel pump relay fails)
Old Dec 30, 2012 | 07:13 AM
CAMAROBEAV's Avatar
Re: Sender Help
Great ! Thanks guys
I'll just put the oil light in the new engine for now and get a pressure guage later
tommy z-28
Oct 6, 2015 10:58 PM
eustodp
Sep 20, 2015 05:09 PM
CatmanFS
Sep 19, 2015 09:00 AM
Ironhead38
Sep 7, 2015 02:26 PM
NBrehm
Aug 25, 2015 11:49 PM
