shorted my dash lights- fuse is fine
Old Jan 5, 2013 | 08:12 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
Ok while wiring up a set of new guages i was testing the various pins to make sure i was getting it right........so i accidently shorted the test light while checking out the dash lights. heard a click, then they went out. I figured it was a fuse....every one in the block looks fine- still no dash lights. is there a relay that i might have damaged? Thanks Pat
Old Jan 6, 2013 | 07:20 PM
hotrodln's Avatar
Engine: Lt1 in IROC
Re: shorted my dash lights- fuse is fine
I ordered a new light switch...the dimmer was kinda flakey...maybe i just finished it off...any other ideas out there?
Old Jan 9, 2013 | 09:36 PM
hotrodln's Avatar
Engine: Lt1 in IROC
ok changed out the light switch. the car needed it anyway...no dash lights......so i pulled the instrument fuse again and took a closer look at it....it had burned through on one end....NOT in the middle.....very hard to see ! so the mystery is solved. on to the next.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Bryan F
Aug 18, 2015 02:28 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
