Are the fuel pump and coolng fan relay wiring connectors the same?
Old Jan 10, 2013 | 09:06 PM
92rs4ever's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Axle/Gears: stock
I've got a 92 camaro rs with the 305/5 speed setup. driving home today and car started overheating so i pulled over to check some things out and found the cooling fan relay melted along with the connector!!! I've located a new connector, but i believe it is for the fuel pump wiring judging by the wire colors. I know that the relays are the same but i thought the cooling fan relay had larger guage wires so my question is, will the fuel pump pigtail connector work in place of the cooling fan pigtail connector or will i risk frying it too? Thanks in advance for any help.
Old Jan 13, 2013 | 07:53 PM
Dan Hubbard's Avatar
Car: K-1 Evoluzione (85 Camaro)
Engine: 5.7L
Transmission: TH700R4
Axle/Gears: stock
Re: Are the fuel pump and coolng fan relay wiring connectors the same?
You risk frying it. The fan pulls a lot more amps than the fuel pump. You can fuse it (protect the wires), and just replace fuses (frequently). Best bet though, is to use the heavier gauge wire.
Old Jan 13, 2013 | 08:05 PM
92rs4ever's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
Axle/Gears: stock
Thanks. That's what I was thinking too. Also the previous owner was using a 30A fuse! No wonder the wires fried and didn't pop the fuse. Idiot
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
