headlights wont come on
Old Jan 16, 2013 | 08:22 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
My 91 camaro headlights will not come on. All other lights work just fine just no headlights low or high wtf is going on its annoying lol plz help could it be headlight switch
Old Jan 16, 2013 | 10:24 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: headlights wont come on
It's possible that it could be the light switch. Another thing is could be is the dimmer/bright switch. When you turn on the headlights, power goes thru the headlight switch then to the dimmer switch then to the headlights. You will need to check and see if power is coming out of the headlight switch to the dimmer switch when you turn on the headlights. Also check the wiring at the dimmer switch and make sure its still hooked up. Does your dimmer switch click when you pull back on the turn signal lever?
Old Apr 14, 2013 | 09:49 AM
Travis Scott's Avatar
D
I'm having the same problem dimmer switch dose nothing no clicking so is it the dimmer switch or head light switch all likes work besides headlights
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
