Help with wireing..
Car: 1991 Firebird
Engine: stock 305
Transmission: Stock auto
Axle/Gears: stock
Help with wireing..
I have a 91 firebird and i just bought a new horn for it (Euroblast) it has positive and negative connections on it. I want to hook it up to the already existing wireing for my horns but i am clueless as to how i would go about doing this. my current wireing works properly i just wanted a louder horn. I do have a relay that came with the horn that has four connectors on it which are 30, 87, 85, 86. and i bought an inline fuse (though I don't even know if i need it) I searched the threads but couldnt find exactly what im looking for so sorry if im posting usless thread. I would be greatly in debt to whomever could give me a diagram of how to do this or could explain it step by step to me.
This is only my second car (only 20) and my first thirdgen ive been putting alot of money and time into her and will be getting a paint job done here in about a month or so. I also just wanted to add that this site has helped me with alot of problems and has pointed me in the right direction more then once in these past 6 months that ive owned this car.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with wireing..
your horn has a relay already use the wire going to your horn and hook to the + of your new horn, take the - lead and ground it to your battery or clean ground like radiator core support.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1991 Firebird
Engine: stock 305
Axle/Gears: stock
true.. 1 1/2 hours was a pretty speedy reply time lol.. am an antsy young adult
and thank you it worked.. im frozen but it worked : )
Only 1 1/2 hours later
