No power to keyed circuits
Old Jan 31, 2013 | 07:31 AM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
After changing out my heater core I forgot to hook up the wire to the electric chock (powered when engine is running only). I stupidly managed to ground it with the engine running. It arced a couple of times and the engine stopped.
I now have power to any of the "always hot" circuits but nothing to any keyed accessories. All fuses and breakers are good.
Any ideas as to where I should start??
Thanks,
Jon
Old Jan 31, 2013 | 11:00 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: No power to keyed circuits
Check the fusible links.
Old Jan 31, 2013 | 12:38 PM
Car: '83 Berlinetta
Engine: 383 CI
Can't think of where there are any fusible links? There's nothing in the engine bay off the battery or anything.
Anything under the dash I can look for?
Thanks ,
Jon
Old Jan 31, 2013 | 01:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I thought the ignition switch controls the accessory power and goes over to the fuse box/
http://www.austinthirdgen.org/index.php?pid=19
Old Jan 31, 2013 | 05:02 PM
Car: '83 Berlinetta
Engine: 383 CI
Thanks for the diagram.
Weird thing, turned the key and got accessory power for a few seconds. Then nothing. Done this a couple of times.
Possibly a short in the ignition causing one of the two breakers in the fuse box to open? Got interrupted so I'll have to get back to it tomorrow.
Old Jan 31, 2013 | 05:31 PM
Engine: Lb9
Transmission: M20
thats weird I wonder if it fried the ignition switch.
Old Jan 31, 2013 | 06:57 PM
Car: '83 Berlinetta
Engine: 383 CI
That's what I'm thinking at the moment. Not sure if it wouldn't be easier to change the whole column rather than the switch. Lol.
I called GM and they still list the switch for $26.00 so at least it's available if that's what it turns out to be.
Jon
Old Jan 31, 2013 | 07:00 PM
Engine: Lb9
Transmission: M20
getting to the connector is not easy just drop the column. You do need to adjust the switch.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
