4th gen headlight switch/Cluster
Old Feb 5, 2013 | 02:17 PM
JacobIroc's Avatar
Car: 92 RS 25th Anniversary
Engine: 305 TBI -> 305 TPI
Transmission: T5/T56
Axle/Gears: 3.08 - 3.73+ soon
Alright, so I finally started my dash swap and I've come pretty far, but hit a huge roadblock >:|....
With the cluster wired to grey -> grey I get the digital ODO displaying, but no other dash lights. Now if I turn the dimmer all the way on, I lose my ODO display but gain the other dash lights -.-... I can turn the headlights on and lose nothing.
With the cluster wired to pink/black -> grey I get super bright everything but ODO.
With both these I always have ODO backlight.
If I connect brown (ODO display) to anything with power, the ODO backlight disappears..
I'm positive I have the cluster wired correctly. The only thing on the headlight switch that isn't wired is the GREY wire on the headlight switch (not dimmer). I haven't seen a difference in anything with it hooked and not hooked up. Everything on the headlight switch is color matched.
What do you guys think my problem could be? Bad random ground? Thanks.
Also. I'm using a signal generator and SGI-5 to give me a 4k PPM.. I know this needs to be wired to the ECM.. Which wire goes from the cluster area to ECM?
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
