diagram for 88 gta dash and alternator??
Old Feb 11, 2013 | 11:09 AM
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
So im having some electrical issues with my dash and my guess is its a ground or something. Car started acting funny the other day after my bolts that hold the bracket for my power steering and the alternator backed out and my belt flew off and then the alternator was touching the valve cover and sparking. Put the bolts back and started the, all seemed fine. From there the dash lights would flicker with the turn signal lights, thought that was a little weird but just thought it was higher than normal resistance in the circuit. But today is where it got a little weird this morning the dash light were flickering and I looked at the voltage gauge and noticed the it was higher than it normally is but jumping from 13 up but not to the red idk if that was just a wire problem or if the volts were fluctuating that much? Then I turned on my headlights and the engine just died as soon as they came on. Started it back up and it was fine no problems drove here to work just fine.
Also would the alternator touching the valve cover and sparking affect driveability in any way? My car seems stronger and smoother after that? Lol but likes to act like its gonna die when I come up on a stop light or stop sign. RPMs dip under 500 to maybe high 300s, then I feel a slight kick and they jump back up to normal and runs fine.
Its the gta with digital dash and alternator is on the driver side. Just trying to see what wires in common they have to see if its a short, loose connection or what else it could be.
Old Feb 11, 2013 | 11:32 AM
Beater79TA's Avatar
Re: diagram for 88 gta dash and alternator??
https://www.thirdgen.org/forums/tech...ce-manual.html
Look for the link by Vader in post #11
Old Feb 11, 2013 | 12:01 PM
TKR 88 GTA's Avatar
Engine: HSR 350
Thanks! Now to go through and find what page lol
Old Feb 11, 2013 | 10:27 PM
TKR 88 GTA's Avatar
Engine: HSR 350
Alright so I went through those diagrams and even tried searching on google and haven't found nothing that connects the 2 circuits. Anybody else think what could be contributing to the problems? This thing is getting me stumped the only thing I can come up with is since the tach and volt gauges are fluctuating with each other a ground G200 (ground behind I/P and next to the steering column). Other than that I cant find a common power that would affect it in this way? I dont see what would cause the engine to just quit after the switch is turned on.
Old Feb 11, 2013 | 10:43 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I had a 1970 Dodge Coronet that happened in. turned out, that the wire that went from the alternator all the way to the gauge was fried. Replaced it, worked fine. Just a thought. But i would pull the dash and check the printed circuit board and your wiring.
Old Feb 12, 2013 | 09:38 AM
TKR 88 GTA's Avatar
Engine: HSR 350
Which wire would that be I dont see it on the diagrams? Never thought of that tho
Old Feb 12, 2013 | 01:48 PM
TKR 88 GTA's Avatar
Engine: HSR 350
How does the volt meter in the digital dash work? Is it just a power from the fuse block for the whole dash then from there it gets its ground from that G200 and the meter just measures voltage like that?
Old Feb 12, 2013 | 06:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pulled the codes to see if anything showing?
Old Feb 12, 2013 | 06:33 PM
TKR 88 GTA's Avatar
Engine: HSR 350
My bulb is burnt out for my SES light. So idk how I can pull codes with that bing off with out a scan tool.
Old Feb 15, 2013 | 08:24 AM
TKR 88 GTA's Avatar
Engine: HSR 350
Alright guys so I finally was able to get out and check my voltage while the gauges were acting wack. Turns out I only have 12.3v to the battery when car is on and the gauges jumping around. So im guessing. The alternator is shorted out when the alternator touched the valve covers and from there it either messed with the voltage regulator or something internal. Also could be a fusable link to the alternator. Is it just the one going from the batter to the alternator thats the fusable link?
89GTAOz
May 16, 2020 09:31 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
Street Lethal
Aug 14, 2015 08:25 PM
