Fuel gauge after TBI swapped to carb...
Old Feb 21, 2013 | 09:35 PM
BroncoRN's Avatar
Car: 1986 Camaro
Engine: 350 - carb
Axle/Gears: Stock
Got this car with fuel gauge not working. 305 TBI was swapped for a 350 with carb. I'm sorting out what was done to the car. Gas gauge doesn't work - pegged past full. Tach needle moves but mostly pegged to 7000. Car is an 86 but gauge cluster appears to be from at least an 88 - 115 mph speedo. I pulled up carpet in the back and hole was cut to access fuel pump/sender from inside without dropping tank. There is a plug? behind the rear seats where wires were cut and spliced and run under the carpet under the rear seats. Oh and motor now uses a mechanical fuel pump. I see three wires coming from pump area - brown, pink, and black. I want a functional fuel gauge. How can I wire up another fuel gauge?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
justin57
Aug 20, 2015 07:05 PM
