Wiring Electric Choke for Edelbrock
Old Mar 2, 2013 | 10:02 AM
Joe Tag's Avatar
Choke for Edelbrock
Ok, so heres my problem. I have the choke wired as edelbrock recommends, to an ignition port on the fuse block, but I want it to not be hot until the engine is actually running. My thought is a 3 prong switched oil pressure sender that closes two of the posts when pressure is on to ground the choke. I'm just not sure whitch sender is applicable, since most are just for dummy lights and not gages. Can anyone telll me a part number for this sender or vehicle/ engine combo for one?
Old Mar 2, 2013 | 02:25 PM
Joe Tag's Avatar
Re: Wiring Electric Choke for Edelbrock
No one has any helpful insight? Possible other ideas how to accomplish this?
Totally open to suggestions.
Old Mar 2, 2013 | 02:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What induction system did the car have originally?
Old Mar 2, 2013 | 03:25 PM
Joe Tag's Avatar
Originally a tpi car, saved it from a junyard with no drivetrain. There is no ecm, and all wiring for it removed.Put a carburated '85 harness in it, but to my understanding , stock choke wire does not run a full 12v which the Edelbrock needs. Don't get me wrong, the choke works fine as it is set up, but I dont want the possibility of turning the ignition on for some reason and have the choke open, then try and start the car and it wont get enough fuel. Wife or daughter may drive it at some point and you know how that goes.
Old Mar 2, 2013 | 03:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Stock carbureted wiring for it will work fine, if you have it all. Or you can take power from the 86 TPI oil pressure switch.
Old Mar 2, 2013 | 03:47 PM
Joe Tag's Avatar
OK,Thanks a bunch.
Ikes 91Z
Dec 9, 2015 03:49 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
1985chevydude
Aug 20, 2015 12:29 AM
86IROC112
Aug 17, 2015 02:00 PM
