Fuel Pump Relay!
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Fuel Pump Relay!
Could someone help me with this problem. I have a 87 iroc that I changed over to carb. I need to wire a relay in so I can get the pump to work . I seen under the tank there is a plug with 3 wires a gray purple an black can I splice them an put the new relay there? I had to rewire the whole car Please a diagram would help or any sugestions would be great! Thank you. Joined: Dec 2004
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump Relay!
on your driver side bulk head wire the orange wire of the fuel pump relay to a switched ignition power.
I dont have a orange wire in the bulk head or a relay on the firewall the only orange wire is in the plug of the connector at the tank above the axal how would i wire the relay to their. Thank you for your quick responce Larry
Engine: Lb9
Transmission: M20
I thought the color back on the tank was pink for the level sender, black for ground and grey for the fuel pump power. the wires run in the body of the car down the drivers side floor and out c100.
Engine: Lb9
Transmission: M20
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Quick question: do you still have the underhood wiring or did you already cut out what was not needed for the carbureted engine?
If you still have the FPOP switch (Fuel Pump Oil Pressure) and the wires attached to it (orange and tan/white), you can reuse that to feed the power fuel pump with the engine running. At that point you could need a prime button to prime the carb bowl after the car has been sitting for a while (days at a time, probably). You would just need to find a source of 12V under the dash (a pink one, since they are powered from ignition) and wire it through a push-button to the tan/white wire that comes up from the driver side floor (under the door sill).
That would be a safer way to wire the fuel pump than directly to the ignition circuit.
Hope this helps.
Lou
Hope this helps.
Lou
