electric fans wiring
Old Mar 18, 2013 | 06:08 PM
tazz3871's Avatar
I have an 87 GTA I purchased two years ago my issue is the person that owned it before me bypassed the electric radiator fan so that everytime you start the car the fans turn on automatically he explained he did this because the car was heating up it seems that he had the wrong rad in place anyone have any idea on how to rewire this so that the fans will only kick on when required
Old Mar 18, 2013 | 07:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: electric fans wiring
You will need to investigate how the mod was done before you can fix it
If he did it the most common way by just grounding the fan relay permanently then all it would require is disconnecting the ground wire and running the wire from the relay back
to a (working) fan switch in the head.
Old Mar 19, 2013 | 04:38 AM
tazz3871's Avatar
Any idea on where the relay is located? Thanks
Old Mar 20, 2013 | 12:37 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If you use the search function you will most likely find that info for your year
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
stalkier
Aug 21, 2015 01:54 AM
