89 IROC cranks but no start
Old Mar 20, 2013 | 03:33 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Well this is another attempt to find some help here in this forum. I finally got my car to crank but it wont start. my SES light turns on but only if i hot wire the fuel pump relay to the battery. i dont have spark though. my cap, rotor, wires, coil and battery are all new also. im thinkin it could be a ground somewhere but im not sure where to look. my grounds behind my heads are connected. ANY IDEAS ANYONE??
1989 IROC-Z 5.7 TPI
Just finished rebuilding my engine also
Old Mar 20, 2013 | 06:07 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 IROC cranks but no start
Does you Ign switch work ;
as in, do you have 12V to the coil when Ign switch is in the Run position ?
Old Mar 20, 2013 | 08:50 PM
KMdoza7's Avatar
Engine: none
i get nothing to the coil. The car does have an msd ignition box though, maybe it went out?
Old Mar 20, 2013 | 08:55 PM
KMdoza7's Avatar
Engine: none
i checked the power and ground cables on the msd box and they checked out but the wires going to my distributor and coil didnt have any voltage
Old Mar 21, 2013 | 04:32 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Run a wire direct from the battery to the coil and see if it fires up.
If it does need to check the ign switch and wire from there to the coil
Old Mar 21, 2013 | 09:57 PM
KMdoza7's Avatar
Engine: none
I just swapped my wiring harness from my 88 iroc into my 89 to see if this fixes my problem and i was wondering if i can use my 88 ecm in my 89?
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mizz0313
Aug 12, 2015 06:45 AM
mustangman65_79
Aug 11, 2015 03:17 PM
