CEL light + fan on solid= Limp mode.....
Old Mar 22, 2013 | 04:03 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
First off the car is a 1991 Z28. Can an unplugged sensor cause a car to be in limp mode with both fans and CEL light on solid right from start up? I thought it was a bad computer so put a new one I had in and still same issue. Started right after a T56 swap. Cant use ALDL to scan as it wont connect. I do not have my Dakota Digital set up yet either. Could the lack of VSS signal cause this?
Old Mar 22, 2013 | 04:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: CEL light + fan on solid= Limp mode.....
I would have thought that's a bad computer, too.
Old Mar 22, 2013 | 08:03 PM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Maybe Ill try to borrow a memcal?
eightsixseven
Dec 16, 2024 01:50 PM
1992Vortec
Aug 31, 2015 08:05 PM
Thaney9
Aug 29, 2015 03:16 PM
LittleFranks
Aug 20, 2015 03:55 PM
Omega
Aug 10, 2015 12:46 PM
