oil pressure wire
Old Mar 23, 2013 | 05:12 PM
hofficer's Avatar
Car: 84 z28
Transmission: t5
oil pressure wire
what wire is for the oil pressure on a 84 z28? Also for the water temp gauge as well as the tach non of them work in my car and have after market tach and water temp but want the originals to work to clean up the dash of the car.
Old Mar 23, 2013 | 05:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: oil pressure wire
Oil pressure sender is a tan wire from the sender on the top of the block beside the distributor, pin E5 on the firewall connector and pin 13 on connector C2 on the back of the IP. The coolant temperature sender is dark green from the sender between the #1 and #3 cylinders, pin E5 on the firewall connector and pin 7 on connector C2 on the back of the IP.
Old Mar 30, 2013 | 07:55 AM
hofficer's Avatar
Car: 84 z28
Transmission: t5
OK what about the tach? I have a aftermarket one in the car was like that when bought the car.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
