Weird Headlight motor problem
Old Mar 24, 2013 | 04:01 AM
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Hi Guys,
One of the 3 wire headlight motors in my car was playing up for a long time, choosing when to open and not so I finally replaced it with another one which lasted about a week and stopped working.
So I tested it out today by following the workshop manual and found the relay had gone for the right headlight, replaced it and it's working again.
My problem is when I measured the voltages the red/white white had 13.5Volts (was trickle charging at the time) which was fine, but when I turned the lights on, the pink wire was only putting out 11.0V.
I tested the other side and both wires were putting out 13.5V each.
So somewhere I'm losing 2.5V and I'm assuming it's damaging to the Relay.
I know the isolation relays are no longer available but does anyone know the part number for the actuator relays for the NON-module headlight setups for the '85 firebirds?
And has anyone had this issue before, or know what might be causing it?
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
