Airbag Sensors..
Old Mar 24, 2013 | 02:36 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Airbag Sensors..
Hey guys, I know the answer is here somewhere, but was unable to find my answer by search. I currently have my whole interior ripped out, and no ECM running the car (Carb) Will there be any problems if I take out the two airbag sensors that are mounted in the passenger compartment? Me gut feeling says no, but I just would like a second opinion.
Old Mar 26, 2013 | 07:27 AM
Stauf's Avatar
Car: 91 Z28 Coupe
bump bump
Posted from Thirdgen.org App for Android
Old Mar 26, 2013 | 10:37 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Airbag Sensors..
Problems? No. But your airbag will stop working.
The airbag system is separate from the ECM and engine so even if you remove the whole ECM and go carb, your airbag will remain operational.
However, if you have a need to remove it, there is also a sensor mounted in front of the radiator.
Disclaimer: I will not be liable for any injuries or fatalities that might result from tampering with the factory airbag life-saving system.
Hope this helps.
Lou
Old Mar 26, 2013 | 04:32 PM
Stauf's Avatar
Car: 91 Z28 Coupe
Thanks.. I will not hold you personally responsible for any issues. The car already has the stock steering wheel removed and replaced with a Grant from the PO. I was just looking to remove some "unneeded" components from the cab while I have a chance. I was just wondering if there would be any "kill" switches activated by removing the sensors.
Eric-86sc
Feb 25, 2016 09:02 PM
1992Z28!
Nov 19, 2015 07:33 AM
tealman92
Sep 28, 2015 01:43 PM
tattmann
Sep 27, 2015 05:20 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
