no release from hatch
Old Apr 3, 2013 | 02:44 PM
87tunedport's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0
i pushed the button to open my hatch and nothing i checked the fuses, i pulled the cluster cover to see if it was plugged in and it was. any ideas?
Old Apr 3, 2013 | 03:49 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: no release from hatch
If you can still open the hatch, take the trim apart and look for loose connectors there.
Possibly the ground is not tight enough back there or has corroded.
Old Apr 5, 2013 | 07:23 AM
Engine: 5.0
unfortunately i cant open it at all i dont even have any lock keys for the car unless i cut the trim up i dont think i can ever get hatch open
Old Apr 5, 2013 | 02:40 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Unfortunately the relay is sitting behind the rear trim.
I also locked myself out a couple of days ago. Was fixing my pull down motor and didn't reattach the unlocking mechanism, so no key helped and no button.
I then folded the rear seat over, reached into the rear to dislodge the compartment louver, pulled it out and then pried off the lamp for the rear compartment.
Behind this is the release mechanism.
If it's not attached, you can push the release lever down and the hatch will unlock.
If it IS attached, you MAY be able to reach the bolt on the upper right of the unlocking mechanism with an angled spanner or something and loosen it enough to remove the mechanism. It'll just fall of more or less.
Edit:
Look at the pic. This is the bolt I mean and the unlock lever behind the assembly would be to the left, just left of that silver stud of the assembly.
At least this is a similar model of hatch pull down motor I have. If you have that brownish plastic thing, I don't know whether this applies.
Attached Thumbnails no release from hatch-t2ec16z-yue9s6ng-scbrgpj071kw-60_12.jpg
Old Apr 9, 2013 | 02:12 PM
Engine: 5.0
Edit:
dude i owe you a beer, i got the hatch open by removing the bolt like you said for the key mechanism. my interior panels are all apart but at least i can reach back there to release the pawl to open hatch. the pull down motor still worked so it must be the switch or wiring going to the motor thanks again
Old Apr 9, 2013 | 03:08 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
You're welcome
Glad I could help.
Old Apr 14, 2013 | 09:55 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, since when is the release relay behind the rear trim? I could swear it is under the dash on the passenger's side, sandwiched between the dash and the heater module. I believe the one behind the rear trim is for the hatch motor...
OP, it should swap with the horn relay in the convenience center behind the ALDL. If the relay is bad, this should get the release working again if the power is good to the switch and the rest of the wiring is undamaged.
Old Apr 15, 2013 | 05:18 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Damn, you're right. Thanks for updating!
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
