PCM pin stuck to harness connector ??!!
Old Apr 5, 2013 | 03:48 AM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
well I just bought this set up for 50 bucks ... and noticed that pin 2 on the PCM side was missing ... well it was in the correct connector but on the harness side? is this a big problem?? its the PCM ground .
its the #2 pin on the red connector ... (pcm ground)
please help does the pin just get pushed back in??
thanks again !
Old Apr 6, 2013 | 07:17 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Re: PCM pin stuck to harness connector ??!!
anyone?
Old Apr 6, 2013 | 07:44 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yep, that's a problem.
If you're handy with a soldering iron, and have a donor pin, you could possibly repair it.
Old Apr 6, 2013 | 08:23 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Yeah I opened it up it broke where the pin bends my buddy said he could fix it thanks
middian
Sep 5, 2015 01:42 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
Slush92RS
Sep 2, 2015 08:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Fox118
Sep 1, 2015 04:07 PM
