Would fuel injectors still work with painless wiring system
Old Apr 6, 2013 | 03:25 AM
Speedrookie's Avatar
Car: 1985 camaro
Engine: 2.8l v6
Transmission: 5-Speed
I just bought a 1985 2.8l v6 Camaro and looked under the hood and saw that most of the wiring was shot. So I am going to buy the painless wiring switch panels .I just wanted to know if I use the switch panels for the fuel pump and ignition system to start the car would the fuel injectors automatically kick in or if not what do I need to do.
http://www.summitracing.com/parts/prf-50301/media------ the switch panels
Old Apr 6, 2013 | 04:27 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Would fuel injectors still work with painless wiring system
So, you basically want to rip out all the existing wiring harnesses, and replace them with aftermarket wiring harnesses that add a switch to the various circuits?
You better be REALLY GOOD at reading wiring diagrams if that is your intent.
In which case you should be able to read the relationships between the injector circuits, and the other circuits on which you will be (re)constructing and/or creating from scratch.
Old Apr 6, 2013 | 12:07 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Same question posted in 3 different forums.
Old Apr 6, 2013 | 12:20 PM
Car: 1985 camaro
Engine: 2.8l v6
yes I know I didn't know what it would fall under this is my 2nd day here so I didn't know if it was allowed
Old Apr 6, 2013 | 12:24 PM
Car: 1985 camaro
Engine: 2.8l v6
I was thinking I could just send power to the fuel pump and power to the ignition system to start the engine, but without the kit the when I turn the key on the engine does spin over. All I need is the engine to start I would worry about everything else later
Car: 1971 Camaro
Engine: 427
No problem.
You got the answer though, right?
Won't work, need a car/ engine/ specific harness.
bryan623
Mar 22, 2021 06:43 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
