reverse lights Isue??
Old Apr 9, 2013 | 03:30 PM
ernie1500's Avatar
new guy here!
I just purchased a 90 formula but in order to get the inspection done I need to fix the reverse lights
the bulbs seem fine and so do the plugs and fuses
where else can I look for the problem?
thanks for your help!
Old Apr 9, 2013 | 04:04 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: reverse lights Isue??
Could Be Your Back Up Lamp Switch.
Old Apr 9, 2013 | 04:42 PM
ernie1500's Avatar
where is that switch located at ?
Old Apr 9, 2013 | 05:12 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It's part of the switch on your shifter, if you have an automatic. On the transmission, if standard.
Old Apr 9, 2013 | 05:50 PM
ernie1500's Avatar
Automatic, what color is the back up light wire(s)?
Old Apr 9, 2013 | 07:52 PM
deadbird's Avatar
Engine: TPI 305/ v6
Iirc, blue is hot into the switch and green is hot out to the lamps.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jetmeck
Sep 4, 2015 12:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
