How much ?
Old Apr 9, 2013 | 06:42 PM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
How much ?
With the car shut off, how many mili-amps should I see across the battery ? I have something draining the battery and I'll be damn if I can figure out what it could be. Checked the obvious, i.e. hatchback pull down motor, seats, window switches etc...etc...Thought I'd start at the battery take it from there.
Thanks in advance
Old Apr 11, 2013 | 08:55 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: How much ?
When doing a current draw test, the reading should be .05 amps or less. Anything more is considered a draw. How are you doing your test?
Old Apr 11, 2013 | 08:59 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: How much ?
Cig. lighter is a big problem, so can stereo amps.
Old Apr 12, 2013 | 03:06 PM
djmarch's Avatar
Engine: 5.7 ltr.
Re: How much ?
Thanks guys for the feedback...I was thinking it was in the neighborhood of a .05 amps. My plan was just to put a multimeter across the positive and negative terminal at the battery with the key in the off position. I will check the cig. lighter as well.
Old Apr 13, 2013 | 02:57 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: How much ?
That's not the way you measure current. If you set the multimeter to measure current (amperes) and you put it across a battery at best it'll blow the meter's internal fuse. At worst you fry the meter.
You need to put the meter in series to measure current. Remove the positive battery terminal from the battery and put the meter between the cable and the battery.
