oil psi gauge/dome light wire slicing
Old Apr 11, 2013 | 12:25 PM
whitecomet's Avatar
Car: 1987 Pontiac Firebird formula 350
Engine: sbc 355 tpi
Axle/Gears: 3.27 posi 9 bolt b/w
i recently put in a mechanical oil pressure gauge it came with a light to illuminate the gauge obviously. I had it wired up to the fuse box but the light bulbs in the oil psi gauge keep burning out for it being on all the time (i put a 20 amp fuse on the power wire as a heads up), i just dont want the light on all the time an i want to be able to see it at night. i would like to splice the power wire for the oil psi gauge into the dome light switch so the light on the oil psi gauge only come one when the cluster lights come on, is this possible or where whould i spice this in to make it happen?
Old Apr 11, 2013 | 03:41 PM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Re: oil psi gauge/dome light wire slicing
Yes its doable, 20A is a way bigger fuse than a gauge bulb needs, think 5A probably more like 1A. If I had my manual I could tell you exactly which wire to tap, without it, probe, better still back probe the wires off the dimmer until you find the one that will change the intensity of the test light as the dimmer is turned.
IIRC GM pretty much uses an orange wire for illum/dimmer
Old Apr 11, 2013 | 04:10 PM
whitecomet's Avatar
Engine: sbc 355 tpi
The 20A is all i had at the point of assembly but i'll swap out that fuse thanks for the help
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
Navy8125
Aug 21, 2015 09:32 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
