hatch motor
Old Apr 14, 2013 | 02:14 PM
jvl744's Avatar
Car: 86 iroc z
Engine: 305 tpi
Transmission: 6 spd
hatch motor
Hi I have a 86 iroc and my hatch motor won't stop running until I unplug it. What is wrong with it. It isn't going up or down either. Thanks
Old May 3, 2013 | 12:30 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Hatch Latch Catch Batch
The leading cause of that problem is stripped gears or a broken lever on the Latch Closed Switch.
If you hear *
click* *click* *click* *click* *click* *click* *click* when the motor is running, that is consistent with stripped gears.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
Old May 6, 2013 | 12:11 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Hatch Latch Catch Batch
Originally Posted by NINÅ
[CENTER][B][COLOR="NAVY"]The leading cause of that problem is stripped gears or a broken lever on the Latch Closed Switch.
I'm agreed with the first recommendation as to the cause. You have a broken gear nut.
http://www.top-downsolutions.com/hat...ull-down-units
Check the Tech Article I wrote years ago that is posted here on TGO under "General Repair" category on repairing these hatch pull-down units:
https://www.thirdgen.org/tech/hatchpulldown.pdf
Lon
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
