wiring reverse or backup lights to a switch
Old Apr 17, 2013 | 12:37 PM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
OK the light green goes to the lights do I can connect that as the load to any toggle switch and connect a fuse ( wiring condom for protection) add power then I should be able to turn them on with the flip of the switch right?
Old Apr 17, 2013 | 05:32 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wiring reverse or backup lights to a switch
Correct
but why wouldn't you use the original blue wire that was the feed to the switch?
No need for any extra wiring or fuses
Old Apr 17, 2013 | 06:13 PM
Engine: 3.1 v6
Last time I used blue and green a fuse popped.
NY b&m mega shifter had the switches, but they would never line UP right and be on all the time.
Old Apr 17, 2013 | 08:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Wiring it up another way instead of solving the problem is just the bubba fix
It worked fine from the factory so you now have a problem to sort out why it is blowing fuses
A direct short maybe????
Old Apr 18, 2013 | 08:36 AM
Engine: 3.1 v6
Most likely the PO butchered alot of the installs on this. I'm just trying to get her to work halfway decent.
Being my dd I can't have it down retracing wires.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
articwhiteZ
Aug 7, 2015 02:25 PM
