distributor module
distributor module
My 91 3.1 seems to be burning up the distributor modules.if i let the car sit a couple days with out using it thats when i notice when it starts it misses for a few seconds, this happen to the last module and at $40-60 a pop its getting a little expencive Thanks in advance for any help
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: distributor module
you must use the thermal/heat transfer grease on the underside of the module . if not used they WILL LAST FAST . good luck .
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Check your coil and wiring
(tests in the link )
http://easyautodiagnostics.com/gm_ic...n_module_1.php
I blew 3 ICM's before I found a failing coil was taking them out
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
