electric short causing misfire
Old Apr 30, 2013 | 04:46 PM
RicerkillerZ28's Avatar
Engine: soon to be changed 3.1
Transmission: soon to be changed 700R2
ok, so i been battling a electrical short. i finally ran it down to the little 2wire plug in the back of the altenator.. if i unplug the 2wire plug the car levels right off and runs like a champ.. but the problem with that is then the car stops charging. i may need to go with a TRUE 1 wire altenator, but would like to know what could be causing this. i have had the altenator checked and it tested out ok. maybe something inside the altenator could be shorting out. has any1 had any issues like this or maybe have a solution. the car used to be a 3.1 v6 now is a carburated 350 with a 350 turbo trans.
thanx
Hotrodboba400
Dec 10, 2019 07:07 PM
Kenwood
Sep 11, 2015 12:50 PM
Ranbo108
Sep 9, 2015 12:20 PM
Jk_Under
Sep 8, 2015 08:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
