fan won't turn off, Choke fuse keeps blowing
Old May 11, 2013 | 07:42 PM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
Last night my fan wouldn't turn off so I just unplugged the two wire connector for it. This morning I tried to figure out what was wrong and I can't even get it to turn on again. It has always ran with the key on all the time too. So I replaced the relay and still nothing. Then I saw that my choke light stayed on while it's running and the choke heater fuse is blown. the last couple days the voltage has stayed around 12, not the usual 13 or 14. Anyone have any ideas? I'm about to say screw it and buy a fan controller kit and try to find all the wires for this choke heater.If it's a charging problem then why would it effect the fan??
Old May 12, 2013 | 04:24 PM
Gsoleski's Avatar
Car: 1984 Z28
Re: fan won't turn off, Choke fuse keeps blowing
here's a little bit of an update. I put a new 20 amp fuse in the choke heater spot on the fuse block, turned the key and it popped. So I put in another, disconnected the wire at the choke thermostat, flipped the key and the fuse was fine. So would the problem be along the choke wire somewhere?
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Derick15
Sep 17, 2016 05:28 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
BrianI
Aug 9, 2015 11:52 AM
