melted connector
Old May 18, 2013 | 02:43 PM
Xphoidz's Avatar
Car: 1992 Firebird
Engine: 3.1 L V6
Transmission: Automatic
melted connector
I have a 92 3.1 liter and i was looking under the hood and there is a connector that I don't know what it goes to, but it is melted some. It is near the Drier. Also if anyone can help me with ac problems that would be cool too. My cooling fan wont turn on and the clutch to the compressor won't spin either.
Old May 18, 2013 | 04:56 PM
88gunmetalgta's Avatar
Re: melted connector
IIRC, when I was pulling my wiring apart, I though that connector was a little melty too, but it ended up just being old dialectric grease or something. I think that particular connector connects the HVAC controls to the rest of the engine harness.
Old May 18, 2013 | 04:58 PM
Xphoidz's Avatar
Car: 1992 Firebird
Engine: 3.1 L V6
So what exactly does it do?
Old May 20, 2013 | 04:23 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lost His Cool
Originally Posted by Xphoidz
……My cooling fan wont turn on……
Apply 12 volts directly to the fan with a couple of jumper wires from the battery.
If it still won’t run the fan motor is defective.
If it does run remove the jumpers and make sure the fan is grounded.
If it is you have an open circuit from the hot in run circuit that was energizing the relay or the direct feed.
If it runs ground the fan switch in the engine.
If it runs the switch is bad.
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
wstephan96
Sep 25, 2015 04:28 PM
