Brake pedal makes gauges lights cut on and off also headlights get brighter???
Old Jun 1, 2013 | 01:20 AM
1BAD84Z28's Avatar
Car: 87 sport coupe
I have an 85 camaro that brake pedal makes gauge lights come on and off. Also the headlights get brighter when press pedal to. I have auto meter ultra lite gauges thinking may be short somewhere im totally lost.
Old Jun 7, 2013 | 06:35 AM
Stallion's Avatar
Re: Brake pedal makes gauges lights cut on and off also headlights get brighter???
Hi. I was thinking it could possibly be a short in your wiring. There should be two grounds for both headlights. Check the grounds on the wiring and check/trace the wires for any cuts or exposed wire possibly making metal contact.
Old Feb 23, 2014 | 07:16 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Transmission: auto 4sp
Axle/Gears: posi
hi I got 91 gta presing brake makes lights go on ? also 4 way flashers not working??
also where are these grounds located? I wish ppl would finish there blogs .
Old Feb 24, 2014 | 07:06 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
My guess is a bad ground in your tail lights.
When you press the brake pedal the brake light filament gets power. Instead of going straight to ground, because it is bad, the current goes back into the running light filament and back feeds the dash/parking lights to reach ground through those lights.
Old Feb 24, 2014 | 08:17 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
there is a relay at the back does that ever fuvk up changed some lights bolbs it was fixed now doing it again . some one must of had this problem . i changed my steering wheel cut air bag wire could this do it before i did this my car did this the odd time 4 way flashers don't work now signal ligts don't work wat a mess well tomarow is another day
Old Feb 25, 2014 | 04:06 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
help I need I need my t.a ready for a rip
Old Apr 18, 2014 | 08:25 PM
gallaire's Avatar
Car: 91 trans am
Engine: ?
Axle/Gears: posi
so what ended up being the problem????
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
