PCM needed for speedo?
Old Jun 4, 2013 | 11:32 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
I have made the conversion to "non-computer" car and having done my first test drive realized the speedo doesn't work. Any way to have a speedo w/o a PCM on my 89 GTA?thanks
Old Jun 4, 2013 | 08:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: PCM needed for speedo?
The '165 ECM used on TPI cars had the speedo (VSS ) signal going to the dash 1st then to the ECM , so removing the ECM should have no effect on the speedo operation
The '730 ECM used on the 90 -92 cars was the opposite ; the VSS signal to the ECM 1st then to the dash
Old Jun 4, 2013 | 09:19 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Good info right there. So where do I check power to see what the problem is. It should be known the VATS has been jumped in case that is part of the equation. I had to run a manual temp gage and toggle for the cooling as it all went through the computer I was told. The tach works and the oil and amp gages register so I believe they work.
IROCZ1989
Jan 24, 2016 03:55 PM
NBrehm
Aug 25, 2015 11:49 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
