Need help With blinkers on 92 Camaro
Old Jun 13, 2013 | 01:13 AM
Chaoticcriz's Avatar
Car: 92 Chevy Camaro
Hey Guys,
I have troubles with my blinkers on my 92 Camaro. When I turn on the blinkers nothing is flashing not even on the dashboard. But when I turn on the flashers the dashboard lights come on.. Should I replace the blinker switch cause I check and changed the light bulb and checked he fuze that goes to the blinkers. Is there something that im missing or do I need to replace the blinker switch.
Old Jun 13, 2013 | 07:43 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Need help With blinkers on 92 Camaro
There are 2 flasher pieces located down under the dash, one is by your fuse block which is the blinkers, and the other is on the right hand side of the drivers side dash located by the buzzer for the lights, they're usually silver, round, and about an inch or so tall, I would check those first
Old Jun 13, 2013 | 07:45 PM
Hey thanks I will check on that.... I will send you another post to see if that is problem... Also I more thing if I need to change the blinker switch do I need to take steering wheel off?
Old Jun 13, 2013 | 08:07 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Oh yeah, its a pain, you need a wheel puller and a lock plate depressor tool, and then getting the switch in place can be a pain, I've done a few and its definitely a practice practice practice job lol
Ultimately if the switch is working I would try to find the issue elsewhere lol I know people that just pick up a whole new column to avoid it
Old Jun 13, 2013 | 09:21 PM
K thanks man... Im trying to get my baby up and running again...
Old Jun 13, 2013 | 09:43 PM
Sorry Man how do you take out the blinker relay?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
