'92 RS can speedo work w/o ECM?
Old Jun 14, 2013 | 05:21 PM
questfor10s's Avatar
I got a 1992 Camaro RS that was converted to carburetor. ECM was removed and I obviously don't have a functioning speedometer and tachometer. Can something be done to get factory speedometer and tachometer to function? Really don't want to have to fork out the money for an aftermarket gauge setup. Any help welcome!
Old Jun 14, 2013 | 07:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: '92 RS can speedo work w/o ECM?
Originally Posted by questfor10s
converted to carburetor. ECM was removed and I obviously don't have a functioning tachometer.!
You screwed something up , the tacho signal comes straight from the coil to the tacho and is not connected to the ECM.
Recheck your tacho wiring
Old Jun 14, 2013 | 10:24 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
The speedo you will most likely need something similar to this.
http://tpiparts.net/inc/sdetail/7587
Thats the one I would need for my car.
You using the same 700r4 tranny? If so I think your gonna have to do something with the torque converter lockup to if I remember correctly. Since the ECM controls that.
Heres a link to a thread on the Speedo
https://www.thirdgen.org/forums/tran...eedo-work.html
Old Jun 14, 2013 | 10:28 PM
Slayze's Avatar
Car: 87 Trans Am
I believe the tach wire is green, but I ain't 100% sure.
Old Jun 14, 2013 | 11:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The tach wire is white, You do not elaborate what the car was originally . Tbi ? 3.1L or what. If it was tbi the vss signal goes to a buffer than to the speedometer and ecm and cruise if equipped. If it was a 3.1l v6 the vss signal would go directly to the ecm and the vss buffer in internal in the ecm. If that is the case you would need to buy a Dakota digital sgi-5 to get the signal to the speedometer.
Old Jun 14, 2013 | 11:15 PM
Slayze's Avatar
Car: 87 Trans Am
Thanks for setting me straight on the color its been awhile and couldn't remember. Maybe it was the new tach I put in that had the green wire.
Old Jun 14, 2013 | 11:16 PM
Engine: Lb9
Transmission: M20
I think your right If I remember correctly most aftermarket tach wires are green.
Jorlain
Aug 24, 2022 05:11 PM
Irocohio
Aug 12, 2015 08:03 AM
marcusaw
Aug 10, 2015 08:13 AM
beachrodder
Aug 7, 2015 04:27 PM
